LabVIEW Embedded
Command mode for HIH Series on Honeywell HumidIcon
Hi guys,
i'm working with the sensor HIH8000 to measure Humidity and Temperature.
But my problem is i can not enter Command Mode. It is said: Command mode can only be entered before 3ms or 10ms Command Window expired( right after power on). I don't know how to get into this 3 or 10ms Command Window.
Here is my project, if you can take a look.
And the Command mode datasheet for the sensor
https://sensing.honeywell.com/command-mode-humidicon-tn-009062-3-en-final-07jun12.pdf
(1,960 Views)
Maybe You can find helpful information in this datasheet. There are information about Using Command Mode since 10 point (page 24).
(1,828 Views)
