LabVIEW Embedded
Cannot program my cRIO-9045 after a clean format - One or more feeds are inaccessible
Hi everyone !
I have my new cRIO-9045, with the latest firmware (25.5.0f112-x64).
I performed a clean format (+set pswd + enable SSH).
Then, the base system installs correctly (Labview 2025).
But, when I am trying to install the CompactRIO/DAQmx etc drivers, then I get the following :
Question No 1: How can this happen, with a new just released 2025 Q3 bundle ?
Question No 2: How should I guess which feed fails? Why its name is not displayed ?
Running manually the 'opkg update'  shows that most probably a gpg_signature related feed is failing, but I have no clue how to overcome this
admin@NI-cRIO-9045-022A4F9B:~# opkg update
Downloading http://download.ni.com/ni-linux-rt/feeds/dist/Packages.gz.
Downloading http://download.ni.com/ni-linux-rt/feeds/dist/Packages.asc.
* opkg_verify_gpg_signature: Signature status returned error: Bad signature
* pkg_src_verify: Signature verification failed for NI-dist.
Downloading http://download.ni.com/ni-linux-rt/feeds/2025Q3/x64/extra/all/Packages.gz.
Downloading http://download.ni.com/ni-linux-rt/feeds/2025Q3/x64/extra/all/Packages.asc.
Updated source 'uri-all-0'.
Downloading http://download.ni.com/ni-linux-rt/feeds/2025Q3/x64/extra/x64/Packages.gz.
Downloading http://download.ni.com/ni-linux-rt/feeds/2025Q3/x64/extra/x64/Packages.asc.
Updated source 'uri-x64-0'.
Downloading http://download.ni.com/ni-linux-rt/feeds/2025Q3/x64/extra/core2-64/Packages.gz.
Downloading http://download.ni.com/ni-linux-rt/feeds/2025Q3/x64/extra/core2-64/Packages.asc.
Updated source 'uri-core2-64-0'.
Downloading http://download.ni.com/ni-linux-rt/feeds/2025Q3/x64/main/all/Packages.gz.
Downloading http://download.ni.com/ni-linux-rt/feeds/2025Q3/x64/main/all/Packages.asc.
Updated source 'uri-all-1'.
Downloading http://download.ni.com/ni-linux-rt/feeds/2025Q3/x64/main/x64/Packages.gz.
Downloading http://download.ni.com/ni-linux-rt/feeds/2025Q3/x64/main/x64/Packages.asc.
Updated source 'uri-x64-1'.
Downloading http://download.ni.com/ni-linux-rt/feeds/2025Q3/x64/main/core2-64/Packages.gz.
Downloading http://download.ni.com/ni-linux-rt/feeds/2025Q3/x64/main/core2-64/Packages.asc.
Updated source 'uri-core2-64-1'.
Downloading http://download.ni.com/ni-linux-rt/feeds/2025Q3/ni-lv2025/Packages.gz.
Downloading http://download.ni.com/ni-linux-rt/feeds/2025Q3/ni-lv2025/Packages.asc.
Updated source 'ni-labview-2025'.
Downloading http://download.ni.com/ni-linux-rt/feeds/2025Q3/ni-main/Packages.gz.
Downloading http://download.ni.com/ni-linux-rt/feeds/2025Q3/ni-main/Packages.asc.
Updated source 'ni-software'.
Also, the HardwareConfiguration UI proposes a list of feeds to enable/disable them, but the above failing one, isn't (obviously) included in anyone of them:
I attached also the TechnicalReport.zip that HardwareConfiguration Guide created.
Any help will be appreciated and thanks in advance for that !
Message 1 of 1
(438 Views)
