LabVIEW Embedded
Arm7 with 32 digital output
Can I get a Arm7 with 32 Digital Input, 32 Digital Output, 8 Analog In and 8 Analog Out,
Some one can provide some information were to get the the hardware or what hardware has the I/O
(7,931 Views)
Hey Javier,
I would suggest taking a look at the parametric search from Keil.com.
However, I believe no board is going to fit your specs.  You are most likely going to need to interface with external IO using serial or I2C in order to meet your total I/O needs.
Please let me know if there is anything else I can assist you with.
Kevin H
WSN/Wireless DAQ Product Support Engineer
(7,899 Views)
Hi Kevin,
thanks for your answer,
what  external interface I/O using serial 12C, could you recommended us to buy for the application.
Javier marte
(7,893 Views)
I am looking for 32 analog inputs (0 to 10VDC).  Did the Keil search and looks like the maximum is 16.  Do you know other companies to try or a way to add more inputs?  Maybe using I2C or SPI?
Message Edited by mfitzsimons on 03-11-2009 12:41 PM
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
(7,614 Views)
I haven't looked so deeply into this but perhaps Atmel have some ARM processors which might fullfill your needs:
http://www.atmel.com/dyn/products/devices.asp?family_id=605
Bjorn Beckman
Application Engineer
NI-Sweden
(7,605 Views)
           I recommend you to take a look EM-AT91SAM3U board. This board uses Cortex-M3 processor, ARM's latest processor product,based on ARMv7 architecture.
           There are also a new real-time operation system CooCox CoOS specially for ARM Cortex-M3. You can get many examples and applications from http://coocox.org/
(7,256 Views)
hello i'm an student of Mechatronic Eng. and I'm a new user with the card ARM7 MCB2300.
i need information about it, how can in make an interface with ethernet, COM ports.
someone would give me information. thanks for all.
(6,047 Views)
