07-27-2007 06:06 AM
07-27-2007 10:38 AM
09-19-2007 02:44 AM
dear professor
i want to ask you some questions about the labview embedded development module.i have got the basic knowledge about it. my probelm is that how can i dowm my program in the arm?i know that there are two ways:
first, we can setup a project in the labview embedded development module,then run it ,it will generate the c code ,and we can compile it using the arm compiler.(such as ADS1.2),but i find there will be many errors.many functions aren't defined.i don't know why
second ,i know that we can down the code in arm directly,but i can't understand the steps.i can get some messages in the Instrumented Debugging(EMB_Porting_Guide),but i still don't what should i do ?
thank you for answering my questions.
10-05-2007 11:05 AM
10-10-2007 04:42 AM
hello,professor Michael P
thank you for your answers,i read the port the run-time libraries (described in chapter 7 of the LabVIEW Embedded Porting Guide) carefully,if i use the uclinux,i want to do some change basing on the unix,but i find i can't change anything,maybe the function using in the unix can also be used in uclinux?
so i want to do the project on the unix?is it right?
thank you !
莲子
10-10-2007 10:44 AM
10-11-2007 04:47 AM
dear professor:
thank you for your answers again!
now i still have a question:i can run the simple program on the arm7(s3c44b0) without os,to begin with the labview development module ,can i also begin to write a simple program in labview embedded module to the arm without os?
if it can do it,we will do the program more quickly!
thank you !
莲子
10-11-2007 12:52 PM
10-12-2007 02:32 AM
10-21-2007 08:47 PM
dear professor:
i ran a simple example using the unix console target,but when i want to build the project,it fail to build,the error message is as follows:
error output:
Open Process Session.vi
i don't know why?
