LabVIEW E.N.A.B.L.E.D Discussions
Reply
RT FIFO
Highlighted
RT FIFO
Hello everyone
In my application, I want to continuously acquire data from 16 differential analog Input channels at 25KS/s/ch sampling rate and want to retain previous 15 min data So that whenever this is a trigger or User Input I can Save this 15 minutes data to any external Device like SD card.
From here what I can understand is for recording this 15 min data I have to initialize the FIFO with :
25000*16(16-bit ADC)*16(channels)=approximate 1 MB data every second
So, for 15 minutes, 1*60*15 = 900 MB of space I need to allocate to FIFO??
Am I on the right track upto this?
Also I want to know the Maximum amount of RT FIFO we can Initialize?
Any Kind of help or suggestions will be really appreciated...
(478 Views)
Accepted by topic author mehrarajat13
10-15-2018 09:49 AM
Re: RT FIFO
You should think of using a hard disk based circular buffer. As a starting point refer the NI tutorial in the link below.
http://www.ni.com/tutorial/3330/en/
Waiting For the inner calling Smiley Happy
(428 Views)
