LabVIEW E.N.A.B.L.E.D Discussions
Connecting sensors to NI modules 9237 and 9401
I want to connect the followings:
1. A pressure sensor Kistler make to NI module 9237. Sensor has 3 wires and a shield.
Sensor has three wires are Output (1 wire) and power (2 wires). Requires 12 volt supply.
I do not know how to connect to this module with 37 pine connector.
2. A crank angle encoder to module NI 9401. The encoder has 9 wires.
The encoder has 3 channels, 2 wires each (total 6 wires). power (2 wires), ground (1 wire).
The module has 25 pin connector.
LD Kala
(1,202 Views)
You need to give more information for the pressure sensor and the encoder.
We can make a lot of guesses at what you may have but having the actual part number or datasheet would help with understanding how to help you.
I would assume for the encoders you have power and AB and Z pulses. You need to set up your daq to read the a b and z channels on digital inputs.
For the pressure sensor we need to know what the output of the sensor is. Is it 0-20mA, 4-20 mA, +/-10 VDC etc... If you are using a sensor that has a mV/V signal then you will need an signal conditioner to get the devise output level in a range the module you have can read it.
Tim
GHSP
(719 Views)
