05-30-2014 03:57 PM
hello
this is pressure control calcul
I want to translate this code in LABVIEW
Note that PH2,PO2 a signal
pressure
Caclul de |PH2-PH2|= ΔP
Si ΔP>ΔPs alors (ΔPs = 6 ou 13 ou 19 ou 34)
Si PO2>PH2 alors Po2 régulée = PO2 – ΔP
Sinon : PH2 régulée = PH2 – ΔP
Si ΔP<ΔPs alors (ΔPs = 6 ou 13 ou 19 ou 34)
Si PO2<PH2 Po2 régulée = PO2 – ΔP
Température :
Testimée (calculée) – Tréf(65C°) = ΔT
Si ΔT > 0 alors T de refroidissement = ΔT
Sinon T de refroidissement = 0
and thanks
06-02-2014 05:40 PM
OK, so start by taking a look at case structures, and at the items on the Comparison palette. Try something and then ask further questions at the point where you get stuck.
06-02-2014 05:56 PM
Even better, ask your questions in the LabVIEW forum where these "help me" type support questions are usually asked and answered.
06-04-2014 08:48 AM
thank you
