LabVIEW Development Best Practices Discussions
Top Three Things in LVOOP That Make You Less Productive ?
fabric wrote:
jlokanis wrote:
Well, I just learned today that if you first select the class and then change the project from 'items' view to 'files' view before you right-click and open the properties, then the dialog will appear in a few seconds!
Interesting! Just tested this and it does indeed work... BUT: The problem is that it can take more than 45s to switch to Files view in a big project! Still a nice tip if you need to edit properties of multiple classes since you only pay the switching penalty once.
I did some informal testing with a medium sized project (~200 classes).
Open class properties from items view with only one class visable (all others in collapsed virtual folders)
10 seconds
Switch to Files View:
<1 second
Open class properties from files view for same class:
1.6 seconds
Open class properties from items view with all classes visable (expand all on whole project)
17 seconds
<1 second
1.4 seconds
Not sure what is causing the slowdown in your project when switching views, but I am not seeing that effect.
-John
Certified LabVIEW Architect
Message 11 of 12
(867 Views)
> Not sure what is causing the slowdown in your project ...
Probably the thousands of VIs. And maybe the hundreds of classes and other libraries.
Message 12 of 12
(867 Views)
