Application developed by Elijah Kerry, CLA – National Instruments
Latest version: 1.0.2.17 (Alpha)
This is the third public release of this library. It is used in a forthcoming version of the Measurement Utility, but valuable enough to warrant sharing it as a separate reusable library.
This library provides a reusable framework for reading parameters from a configuration file on disk, displaying them to a user and returning them to a calling framework. A developer who wants to inherit this dialog needs to create a child class of the Configuration Dialog Actor and implement the following:
- Define the configuration parameters in the private data control of the child class
- Extend the store and read methods (by inheriting them) to define how these parameters are loaded and stored to disk
- Override the 'Store Static VI References Methods' to add static references to the VIs that should be displayed in the SubPanel
- Implement the SubPanel displays using the template in the example (shown below):
Installs the template for a SubPanel item into the 'Create Projects' dialog
OpenG Application Control Library >= 4.1.0.7
OpenG File Library >= 4.0.1.22
OpenG Variant Configuration File Library >= 4.0.0.5
FYI, the dialog needs some work if you're working on a non win7 default display setup
Not to mention the ability to set the title! Oops...
What specific changes would you want to see for your display settings? Less margin at the top?
How's this? (more like the LabVIEW dialog)
Better
Is it resizeable?
Hi Elijah, is localization possible with this approach? like in... http://www.ni.com/example/31257/en/ (LCE)
Any chance of a version of this that I can open in LV2012?
Any chance of a version of this that I can open in LV2012? [2]
Tried to convert from a labview 2013.
It showed an error pointing that two VIs had objects that is not present in previous version:
Display new Configuration Subpanel.vi
Construct Configuration Object
I am trying to see if i can work around but if anyone already have it working for LV2012 and can share it I'll be grateful
It says: "Missing oject. The object Attachment does not exist in the previous version"
Don't worry about that. The "attachment" is just the arrow connecting a comment to the thing it is commenting about. It is a comment change only.
Thanks.
It' working now. I thought that the problems i was having came from the missing object, but i had a problem in my code. If have any other issue I'll post here, but it seems to be smoothly.
Elijah_K thanks for sharing this code!
Hey Elijah_K, this is a very useful piece of code.
I usually have the problem of wanting to configure multiple things at a time, and which of these things are available for configuration is sometimes determined at runtime. Have you considered setting the Config Actor up in a way to support Nested Actors in such a way that the root Config Actor would handle the UI and the nested actors only supply the static subpanel VI refs and the storage routines?
I might look into it at some point.
