LabVIEW Development Best Practices Discussions
Reply
Blockdiagram Zoom Out
Hi ,
i have very wide blockdiagram even after i select all the items and click on CLEAN UP DIAGRAM button i want to zoom it out to see all the blocks and i can't use subvis
Message 1 of 10
(3,623 Views)
This widget could not be displayed.
You can not zoom in labview but you might find the navigation window usfull (cntr+shift+N)
Message 2 of 10
(2,802 Views)
What kind of application is this?
I can only think of very very few cases, where you can't use SubVIs
Programming languages don't create bad code, programmers create bad code....
Message 3 of 10
(2,802 Views)
Actually I can't think of any reason NOT to use subVIs.
Rolf Kalbermatter
Averna BV
LabVIEW ArchitectLabVIEW ChampionLabVIEW Instructor
Message 4 of 10
(2,802 Views)
The most interesting aspect of this question is thinking about why you couldn't use subvis. I'm struggling to think of a single use-case.
Message 5 of 10
(2,802 Views)
I have seen cases in FPGA where you need a lot of wires for functional blocks (VHDL nodes, custom devices, etc.) that would be nice to put into subvis (like "acquire" -> "store/log" -> "compare" -> "compute Simulink/Veristand" -> "output", something like that) just to tidy up your block diagram but you wouldn't want to bundle/unbundle or build/index arrays for resource reasons?
Joerg Hampel | CLA, LabVIEW Champion, DQMH Trusted Advisor | hampel-soft.com | alarchitects.org
Message 6 of 10
(2,802 Views)
Generally on FPGA bundles, unbundles are free anyway since there is no memory, just wires.
The case I can think of is the if you are using locals or implicit property nodes (IF you are unaware of the alternatives to these).
James Mc
CLA and cRIO Fanatic
My writings on LabVIEW Development are at devs.wiresmithtech.com
Message 7 of 10
(2,802 Views)
Hi
I can use subvis in my application , sorry i meant to say that i don't want to use subvi
Any way thank you
Message 8 of 10
(2,802 Views)
Independent of the IDE you're using there's some style guidelines you should adhere to.
A block diagram that is so  huge that you consider zooming is definitely an indicator that you should SubVI's. SubVI's increase the readability and reusability of your program.
Saying that you don't want to use SubVI's is a bit like saying you want to write a well-readable book, but without any chapters, interpunction etc..
Message 9 of 10
(2,802 Views)
Highlighted
For what reason?
This conversation reminds me of this quick story: The Dense Forest.
Message 10 of 10
(2,802 Views)
