LabVIEW Communications System Design Suite
Re: labview task scheduler
Hi
My name is Mohith I'am a student how is new to Labview Communication Design Suite. Recently i have been given a small task to implement a scheduler which allocate the resources based on the SNR of the UEs in LTE Application framework. Can you please guide in any possible ways.
Cheers
@Albert.Geven wrote:
reading the time each minute and checking against a tasklist (including dates and time and done boolean) would be easy enough.
In your idle loop (you always have in a nonstop program) check this and up you go. (I would read in new tasks once a day or add a task user interface)
(3,097 Views)
Hi
Cheers
(3,083 Views)
Hi
Mohith here I'am a student who is new to Labview Communication Design Suite. Recently i have been assigned a small task to implement a scheduler which allocate the resources based on the SNR of the UEs in LTE Application framework. Can you please guide in any possible ways.
you can reply to: mktech.dis@gmail.com
Cheers
(3,080 Views)
Hi Mohith,
Are you looking to expand the LAA example to a multi-UE system?
Cheers,
Rahul
Rahul B.
(3,061 Views)
