07-14-2017 02:52 PM - edited 07-14-2017 02:53 PM
A multirate file was developed and tested with success on host. The file envolves add, minus, multiplication, operations complex to polar conversion and conjugate.
When I change the target from Host to USRP appears:
- Error: the optimized FPGA VI did not compile correcly
- Warning: informing that the clock rate cannot be reached
I didn't select the option "Optimized FPGA" for any one file on this project.
The Throughput for each input and output to low value: 1 Msps
The clock rate value for the file was configurate with 4 MHz and with 40 Mhz, but the problem not disapear;
Do you have some suggestion how solve this problem?
The picture show the mentioned errors.
Thanks in advance.
Have a nice day.
07-19-2017 02:00 PM - edited 07-19-2017 02:01 PM
Hello Julianosf,
Can you send me your source code? With that I can try to reproduce the issue at NI Office. In parallel with that I will make some research to try to find a solution.
