LabVIEW Communications System Design Suite
Reply
Implementing a 2x2 MIMO using USRP 2901
Hello, I have two NI USRP-2901.
I want to implement simple 2x2 MIMO.
And, I found these phrases on the website : 2 USRP-2901 software defined transceivers (2X2 MIMO, 70 MHz to 6 GHz)
But I can not find any related data or documents or example code.
I have already looked at the white paper using USRP-292x. (http://www.ni.com/white-paper/13878/en/)
I really need to know that it's impossible with 2901?
If possible, how can I implement 2x2 MIMO with 2901?
(928 Views)
Highlighted
Re: Implementing a 2x2 MIMO using USRP 2901
I tried this example by using USRP-2901 at LabVIEW Communication Design Suite but it doesn't work. When u examine this document, it will help u.
https://www.ettus.com/content/files/kb/mimo_and_sync_with_usrp.pdf
(889 Views)
