LabVIEW Communications System Design Suite
FIR filter coefficients set for PSS synchronization
Hello all
Referring to this question: Sub-carrier-spacing-in-LTE-application-framework
I'm trying to modify the number of subcarriers in 20MHz LTE AF
Now stuck in the sync process between TX and RX, as LTE AF RX used 2 FIR filters for cross correlation
Use FIR filter to decimate 16 also really confuse me
In LTE AF cross correlation, used 2 FIR filters with 3 coefficient set, each set has 128 elements
At begin I think FIR coefficients set are just the PSS sequence after IFFT and decimate 16
3 coefficients set of 3 cell ID candidates
But I just realized that maybe not true, one of the FIR filter's last 2 coefficient sets are exactly the same
The other FIR filter's last 2 coefficient sets has the same number, but with opposite sign
How do those FIR coefficients actually related to the PSS sequence we generate in TX?
(2,629 Views)
Another question about cross correlation VI
In the study I realized it needed 3 real value FIR to filter complex value signal
but in this VI only had 2 FIR?
(2,594 Views)
