LabVIEW Communications System Design Suite
Can't use third party simulation mode in PXIe-786xR
Accepted by topic author rafiqa
Hi rafiqa,
If you haven't, I'd recommend posting this question in the normal LabVIEW discussion forums rather than here. This forum is for the LabVIEW Communications System Design Suite which is a LabVIEW NXG Suite. The workflows in that software are different from LabVIEW FPGA.
That being said, this document should be somewhat helpful: Cycle-Accurate Simulation with Xilinx ISim. Two comments:
1. You should choose the Xilinx Simulator instead of ISim in the LabVIEW Options, but I think most of the instructions remain the same.
2. You will need to have the LabVIEW FPGA Xilinx Compilation Tools installed locally for this to work.
Charlie J.
(5,006 Views)
Thanks for the information...
(4,941 Views)
