LabVIEW Communications System Design Suite
急急急!!!LTE-U/LAA framework can't change data source for UDP to transmit vedio through VLC
想用LAA/LTE-U framework传数据,结果packet loss in 一直处于亮着的状态,bat文件也是按教程写的(且改变端口802.11可以用),用VLC往50000打stream流,然后用另一个VLC监听60000端口,发现并没有数据过来,
(3,853 Views)
 maybe you can try to Use an older version of VLC (2.1.5 seems to work)
http://download.videolan.org/pub/videolan/vlc/2.1.5/win32/vlc-2.1.5-win32.exe
thx
(3,631 Views)
Thank you very much!
(3,586 Views)
