LabVIEW APIs Discussions
disable a daq
Is it run parallel?
If it is, take care of the DAQmx channels. If some of them (DAQmx channels) are used in stabilizer, do not use them in other process to generate or acqure signals, select different channels.
+++ In God we believe, in Trance we Trust +++
[Hungary]
Message 11 of 15
(1,142 Views)
i can read the same signal from 2 diferent channels?
Message 12 of 15
(1,142 Views)
Yes.
I would suggest you to take a look at the following link: http://www.ni.com/white-paper/5434/en
And use LabVIEW example finder with the "DAQmx" keyword. ( Help - Find Examples ).
[Hungary]
Message 13 of 15
(1,142 Views)
ok ,thanks
i will see it
thanks for your aid
Message 14 of 15
(1,142 Views)
You're welcome!
[Hungary]
Message 15 of 15
(1,142 Views)
