12-09-2009 04:31 PM
I've been working on some code to wrap VIs on a diagram in a disable structure and I'm having a problem. Whenever the code executes the 'EncloseSelection' method, LabVIEW (8.6) crashes. I haven't tried this on LabVIEW 2009. For what its worth the object I'm selecting on the block digram (that is getting 'Selected=T') in the screenshot is a subVI on a diagram. Is this a LabVIEW bug or am I doing something wrong or does the method just not support 'DisableStructure' objects?
I can't really tell what the problem is but I've attached the crash dialog.
Thanks in advance.
12-11-2009 11:22 AM
OmarMussa,
I've tried enclosing a selected SubVI in a diagram disable structure in LV 8.6 and LV 2009. In both of these the operation silently fails, but does not crash.
Is there some way you can send me a copy of the acting and target VIs you're trying to perform this operation with? You can reach me at trevor.christman@ni.com.
-Trevor Christman
12-16-2009 09:13 PM
Sorry, I was out of the office for the last few days. I'll send you an email as soon as possible.
