02-10-2011 05:00 PM
I am thinking about a RCF toolkit that generates a combo constant that has the current set of cases for a case-structure (like a string-based enum). It would lack auto-updating but would prevent typo's.
I could not get it to set a list of strings, but it wouldn't return the list of strings either. The following snippet errors out (error 1058?), if I prepare a diagram with only a combobox constant (like the one in the lower left). Anybody knows how to access these options?
Ton
02-10-2011 05:11 PM
Try to retrieve Strings and Values[] and see if that helps.
02-11-2011 12:57 AM
String and Values works.
Ton
