LabVIEW APIs Discussions
Get progress when building an EXE with Application Builder API
Found out about the U64 input to "Load_From_Project.vi".
As per https://forums.ni.com/t5/LabVIEW-Project-Providers/FAQ-about-LabVIEW-Project-Providers/m-p/3494834?p...
you can use the following to get it: <LabVIEW>\resource\Framework\Providers\Common\provcom_GetObjectItemFromProjectItem.vi
for which you can supply build spec ref. Lo and behold, I was able to programmatically build with progress (see attached example)!
Merry Christmas! 🙂
Message 11 of 17
(4,419 Views)
The example was LabVIEW 2020 though. Attached are 2015 and 2018 versions.
Message 12 of 17
(4,415 Views)
Merry Christmas indeed! Hopefully the OP sees this and marks it a solution. But just in case:
^^^Solution for building installers with progress by @RogerSaele
Thanks for posting.
Message 13 of 17
(4,387 Views)
Just discovered that one can also use "AB_API Get Build Object.vi" (which is used by "Open_EXE.vi", first VI in Voky's solution, from "NI_AB_API_EXE.class"), selecting installer as build object type, and providing project refnum and build spec name:
The build object output can be used as input to "Load_From_Project.vi".
Message 14 of 17
(4,303 Views)
Yet another solution. Opens up a native LabVIEW build window.
Message 15 of 17
(3,584 Views)
@Voky  escreveu:
Hi Matthias,
Sorry this is a little late.  "Create progressbar event.vi" creates user events for the Application Builder API to pass messages with, I would guess the normal pop-up window utilizes these events.  Below is a quick and dirty snippet example of using these events to show build status.
-Voky
I tried to build a RT application using this approach, it worked fine, but when I added the WebService to the buildspec I got a "Recursive Call at Build_Restful.vi" (I need to get the exact error and update the post), and then the build stopped.
Anyone else had this issue before? (LV 2017SP1)
Message 16 of 17
(3,199 Views)
@felipefoz  escreveu:
@Voky  escreveu:
Hi Matthias,
-Voky
SOLVED!
There is a bug in the Build.vi when trying to build an application with web services.
The fix consist in changing the reentrancy of the Build.vi from Non-reentrant to Shared Reentrant and of course all the implementations of the Build.vi in different classes (it is a dynamic dispatch VI)
This is possible with newest version of the LabVIEW where this API is not password locked.
Message 17 of 17
(3,087 Views)
