LabVIEW APIs Discussions
Can I set the color of a control programatically?
I would like to set the color of front panel controls by scripting. This only seems possible for some elements. A cluster has the property "Color",  a boolean element has "Colors[4]" and a decoration and a tab control have "Colors". What is about the other controls like numeric, array, string and ring?
Greetings,
shb
(3,854 Views)
First, you can't set color on "system controls".
Then for other controls, it depends really... For strings/numeric/path for instance you can set different colors for different part of the control.
For a numeric : property > Numeric Text > Text Colors > BG Color + Text Color : that's for background color plus text color.
Hope this helps a bit
Epictetus
Antoine Chalons
(1,079 Views)
did u try to use property node for the controller u want change its color ?
Lecturer
Machanical Power Department
Helwan University, Egypt
(1,079 Views)
Not exactly I am afraid...
For the "system controls", you could set the text color but background color via property node
(1,079 Views)
