01-18-2011 10:20 AM
I would like to set the color of front panel controls by scripting. This only seems possible for some elements. A cluster has the property "Color", a boolean element has "Colors[4]" and a decoration and a tab control have "Colors". What is about the other controls like numeric, array, string and ring?
Greetings,
shb
01-18-2011 10:32 AM
First, you can't set color on "system controls".
Then for other controls, it depends really... For strings/numeric/path for instance you can set different colors for different part of the control.
For a numeric : property > Numeric Text > Text Colors > BG Color + Text Color : that's for background color plus text color.
Hope this helps a bit
Epictetus
01-18-2011 10:36 AM
did u try to use property node for the controller u want change its color ?
02-12-2012 07:41 PM
Not exactly I am afraid...
For the "system controls", you could set the text color but background color via property node
