LUGG - LabVIEW User Group at Goddard
This code snippet prints a VI front panel to a PDF file using PDF creator as the printer.  The code is LV2014.  If you have an earlier version, please just use the picture to reconstruct the diagram.  This is the code that was presented at the LUGG meeting on 6/8/2016.  -Steve
(7,570 Views)
This code also requires PDF Creator to be installed.  CAUTION:  INSTALLING PDF CREATOR CAN RESULT IN ADWARE BEING INSTALLED ON YOUR COMPUTER.  PLEASE REFER TO THE POWERPOINT DOCUMENT ON HOW TO INSTALL PDF CREATOR.  BE ADVISED: IF YOU DO NOT WANT TO RISK THE ADWARE BEING INSTALLED, DO NOT INSTALL PDF CREATOR.
(7,095 Views)
