Hobbyist Toolkit
loss connection to target when deploy project to rpi 4
you're right. Messing up with files and install LabVIEW manually is not RECOMMENDED 🙄.
thanks for your help.
Message 11 of 15
(1,709 Views)
Raspberry pi 4 lost ethernet connection after LINX target configuration uploaded Labview services. It happened after Rasberry pi 4 rebooted. LINX still has big issues.
Message 12 of 15
(1,678 Views)
I have the same issue, is there any fix for this already?
LabVIEW version: LabVIEW 2020 32-bit
Pi: Raspberry Pi 2B
Now, When I try to run the example for the first time, it gets connected, and deployment is successful. Once, the deployment is done, I get the connection lost error as below,
I click 'Ok', and VI stops. Now I rerun the VI. It says "Failed to connect to target"
But in the "Target Configuration" Window, the connection is still successful on clicking connect
I have to restart "pi". And connection becomes successful through an example. But on deployment, this repeats again.
Please help.
Navin Subramani | CLA, CTA | boring engineer
Message 13 of 15
(1,591 Views)
Exact same problem and screens!! Is there any fix ?
Message 14 of 15
(1,546 Views)
I was having the same problem as what you are seeing.
What was causing my issue was the fact that I had 1-Wire enabled.
(Preferences > Raspberry Pi Configuration > Interfaces)
Try disabling this and see how you get on.
Message 15 of 15
(1,281 Views)
