Finally installed Beaglebone Black driver by disabling signatures in Windows 10. Now I can't get the Labview LINX Target Configuration VI to run to connect to BBB. When I select the drop down menu and click on Tools/MAKERHUB/LINX/LINX Target Configuration, I get the VI with a broken Run control. Clicking on Run shows no errors in the VI. It seemed to run before I installed the BBB driver but could not connect to BBB because the driver was not installed. Also I attempted to install LINX V3.01.192 using VIPM at some point and got an error 7 and some indication that LINX was already installed. Could I have broken the LINX add-on? Can it be repaired?
