Hobbyist Toolkit
SPI communication without sending data
We are using LINX for SPI to communicate between a BeagleBone Black and custom hardware (amplifier that sends voltage values). We can configure the hardware with LINX for continuous or non-continuous reading successfully and now receive signals correctly. We would prefer to use continuous reading (to achieve constant sampling frequency), but it seems this necessitates that we send an array to receive an array. Is there anyway to just listen to an SPI port and read data when available? Or is it necessary to send data?
We have instead moved forward with non-continuous communication at variable sampling frequency, which we then re-sample from labview (point by point spline interpolation). This works (finally), but we would definitely prefer continuous reading with hardware specified timing.
Anyways, I thought I'd check before abandoning continuous communication entirely.
Thanks!
Message 1 of 1
(984 Views)
