I have an Arduino Mega board, which allows 16 (A0-A15) analog input connections. I have the first 5 (A0-A4) analog pins connected to circuits that include FSR sensors. I want a single voltage meter and waveform chart to show the output (in V) of whichever sensor is triggered, so I tried merging the signals from each analog in pin, then running the merged signal into a voltage meter and waveform chart. The problem is that only values from the A0 pin FSR sensor are showing up on the voltage meter. There is never more than 1 sensor triggered at the same time, so I thought the meter would show the value of whichever sensor was currently triggered instead of showing 0V at all times unless the sensor connected to A0 is triggered. I also added in an image of the block diagram I currently have if that helps make sense of what is mentioned above. I have a meter for each sensor connected to an analog input pin so I can make sure the sensors are actually working as they are triggered. When, for example, sensor 2 connected to A1 is triggered the value will show on A1's voltage meter but not on the merged sensor meter. I don't have previous experience in LabVIEW and have been reading up a lot on forums, but just haven't found anything that can fix this issue or let me know if it is even possible to do! Since the sensors work individually I know it is something with merging the signals that is causing the issue, not sensors that arent connected well or wired incorrectly. Thank you in advance!
