04-28-2021 05:37 AM - edited 04-28-2021 05:43 AM
Beta version 1.6.0
04-28-2021 09:03 AM
I like the Pretty Print!
04-28-2021 09:33 AM
Just to show one design goal, which is to recover from common User errors with editing JSON files, here I use Notepad++ to cut and paste the "A" parameter from the top to the bottom of the list. My common error is to not adjust the commas (one is missing, and an extra one is "trailing" the list):
"Pretty Print" will correct such comma errors, so on reading the config we get:
05-26-2021 10:56 AM - edited 06-10-2021 03:51 AM
Beta 1.6.2:
--> Adds support for Sets and Maps in 2019+
See https://bitbucket.org/drjdpowell/jsontext/issues/74/add-support-for-maps-set
Note: with no Sets/Maps in 2017, I am using slower old-school flattening techniques to support them. I can also not add them to my Unit Test suite (as it is in 2017), so this could do with User testing to find edge cases.
05-26-2021 11:06 AM
I am stuck in LV2018 for hardware that went out of support after that. Really appreciate you making this non-breaking in 2018!
Does it support variant-attribute maps in 2018? I made my own dictionary and set utilities based on them, and would really love to serialize them with your library. I am switching to JSONtext for all forward development.
05-27-2021 08:17 AM
Going from a Variant-attribute map to JSON is implemented, but the reverse journey is not. The reverse is problematic, as JSON doesn't carry the precise LabVIEW type to convert to, so if I wrote it, it couldn't properly convert any types but strings, numbers and booleans. Which is probably useless for you.
I don't actually use Variant-Attribute Maps like this, but I might be able to help. Possibly I could save type information. Or you could provide a type (if all your Map attributes have teh same type).
06-02-2021 09:43 AM - edited 06-10-2021 04:21 AM
Beta 1.6.3 (fix issue with not working for Clusters in Sets/Maps; https://bitbucket.org/drjdpowell/jsontext/issues/74/add-support-for-maps-set
06-07-2021 03:41 AM
1.6.4: just updates the documentation on teh new features.
06-29-2021 11:42 AM
1.6.5 is now published on the Tools Network servers.
