why this Function--viVSPrintf doesn't work in VB6.0?
Dear Expert:
  I'm a newer of VB,now my problem is:
  I use VISA32-DLL,when I run:
   For i=0 to 50
   Call viVSPrintf(vi, Temp, "FREQ:CENT %dMHz", (925 + i * 0.2))  -------------Temp As String;vi As long
   Call ibwrt(ComHandler, Temp)
  I can't get the Temp value,so I can't write the string to control the R&S FSQ,
  How to config the parameters of this function:viVSPrintf?why I can't get the String?
(3,300 Views)
Instead My purpose is writing a expression into a String because GPIB command ibwrt() can't support a String with variable,
and I'm not sure if the parameters i wrote is right?
i will appreciate any information from you,thanks
(3,298 Views)
