viOpen is not defined in my VBA code
I download NI-VISA 4.6.2 and wrote a VBA code to use NI-VISA to control Anritsu VNA.
my code is
status = viOpen ( defaultRM,"TCPIP::".........)
VBA program shows a compile error: Sub or Function not defined ( viOpen is highlighted)
I think I miss something in my Reference but don't know which one. I include all files seem related to NI-VISA in my reference.
(3,093 Views)
Can you tell us the exact error message that you are getting? Is it "symbol undefined"? Did you link visa lib?
(3,079 Views)
VB program shows
" Sub or Function not defined "   and the viOpen is highkighted.
I am not sure I link all VISA lib. How to check it ?  Thanks
(3,067 Views)
Accepted by topic author xinli
I found the problem. I need in Tool/Reference add VISA32.dll from NI VISA.
(3,058 Views)
I suppose that is what i meant. Never the less glad you found the solution...:smileywink:
(3,040 Views)
I know this post has 10 years, but, in fact I have the same problem.
I am not used to program using VBA in Excel, nor using VISA.
I just want to parameter my Rigol DG822 arbitrary generator.
At first, I installed the NI-VISA suite, in the VBA references, I activated VISA-COM 5.12 Type Library and VISA-COM 488.2 Formatted I/0 5.12.
My code is simply issued from the Rigol DG800 programming manual :
Sub QueryIdn()
Dim viDefRm As Long
Dim viDevice As Long
Dim viErr As Long
Dim cmdStr As String
Dim idnStr As String * 128
Dim ret As Long
'Turn on the device, and the device resource descriptor is in CELLS(1,2) of SHEET1'
NO_LOCK, 0, "")
viErr = visa.viOpenDefaultRM(viDefRm)
viErr = visa.viOpen(viDefRm, Sheet1.Cells(1, 2), 0, 5000, viDevice)
'Send request, read the data, and the return value is in CELLS(2,2) of SHEET1'
cmdStr = "*IDN?"
viErr = visa.viWrite(viDevice, cmdStr, Len(cmdStr), ret)
viErr = visa.viRead(viDevice, idnStr, 128, ret)
Sheet1.Cells(2, 2) = idnStr
'Turn off the device'
visa.viClose (viDevice)
visa.viClose (viDefRm)
msg.Close
End Sub
In Cell 1.1, I have  USB0::0x1AB1::0x0643::DG8A224203417::INSTR
In F8 line-debugging, it stopped at the the first VISA commande (visa.viOpenDefaultRM(viDefRm)), saying "object required / error 424".
OK, error 424, means the VISA commande is not understood. And so what do I need more than the reference activated to do that ?
In C:\Windows\System32, I have visa32.dll and visa64.dll.
But, the VISA-COM reference in VBA does not point on one of these files, but on C:\Program Files\IVI Foundation\VISA\VisaCom64\GlobMgr.dll, and I am not allowed to changed that.
May someone good help a poor crying man ?
Thank you very much for the knowledge :
Best regards
Fred8
(181 Views)
