04-22-2014 01:57 PM
I am using Windows 7. I have a GPIB_USB_HS adaptor and I can not change the GPIB Interface ID (Primary address). The NI max says you should be administrator to be able to change (while I am the administrator). The fields are gray and no access to change.
I do not have this problem with the same adaptor when I use a PC with windows XP.
Please advise.
04-28-2014 04:33 PM
Hi nshayan,
Right click MAX > Run as administrator and try again. I tried it on my end and it looks like it works.
04-29-2014 06:22 AM
When you are logged in as administrator, what you said works, thank you.
What if some user other than administrator wants to change the primary address, because this is the case for us.
As I mentioned, for windows XP, everybody can do the change.
N Shayan
04-29-2014 06:47 AM
10-31-2019 03:09 PM
I have the same problem. I tried connecting a GC with an autosampler and ChemStation. In Chemstation the Configuration Editor does not have an address up to 30. It ends at 29. But the card is 30 thus the PC cannot connect to the GC. I that I get is GC not found, make sure you have configured the GC correctly
