12-16-2008 11:51 AM
I am trying to use a TDS 3034B oscilloscope to take autonomous measurements. I'm using LabView 8.0 and I have downloaded proper drivers.
As of now I can control the oscilloscope settings and take measurements. The problem is that I can't find a vi that controls the horizontal scale of the oscilloscope.
The channel configuration vi only has the vertical scale.
Any help is appreciated.
Solved! Go to Solution.
12-16-2008 12:15 PM - edited 12-16-2008 12:18 PM
Use Configure Acquisition Record. It would not be a channel config since the horizontal timing applies to all channels.
Assuming that you are using the project style driver, there are examples in the example finder - Hardware Input and Output>Instrument Drivers>LabVUIEW Plug and Play. You would have seen the above function in a couple of them.
12-16-2008 12:48 PM
That worked. I had an incling that it might be somewhere in those acquisition vis just didn't try it.
Thank You
