09-22-2015 01:03 PM
I am working on a little side project to try and establish ethernet communication between a PC and a sbrio-9651.
I was just wondering, does it matter if the cable is a cross over cable or not?
Also, what are my options for ethernet communication? I wanted to get an overview for the different methods of communicaion so I could pick the best method.
Any literature or general advice for this project will be much appreciated.
09-24-2015 05:49 AM
I am Ed at National Instruments Technical Support. I'm happy to assist you with your query.
You can use either a standard cat 5 LAN cable or a crossover cable, a crossover cable is a LAN cable however the wires are "crossed over" so that the transmission lines at one end, are receiving lines at the other. You can use a LAN cable however and handle this programmatically knowing the cable lines. I have included below a link outlining the crossover cable to provide an illustration:
https://en.wikipedia.org/wiki/Ethernet_crossover_cable
With regards to protocol usage I believe these articles linked below will provide you with the information you need as to standard communication.
1. http://www.ni.com/white-paper/5761/en/
2. http://www.ni.com/white-paper/5206/en/
3. http://www.ni.com/white-paper/12558/en/
4. http://searchnetworking.techtarget.com/definition/TCP-IP
5. http://kmbsmanuals.konicaminolta.us/bizhub3300P4000P4700PNetworkingGuide/what-is-auto-ip-topic.html
6. http://www.ni.com/white-paper/6746/en/
Note: Section 1 of link 4 is extremely useful on covering the core basics of internet communication and "handshaking" between devices. Link 1 describes the different Industrial-Based communication protocols you could use.
I hope that this is helpful and you are successful in your application.
Ed
09-24-2015 05:51 AM
Hi Ed, thank you for getting back to me.
Do any of those tutorials or papers include how to establish ethernet communication using the FPGA Module and/or Real Time Modules?
09-28-2015 06:02 AM
Can anyone help me with this query?
Any form of serial communication will do.
Need to understand how to send serial data from an FPGA device to a PC or vice versa
09-28-2015 07:57 AM
Okay I believe the following links with regards to the sbRIO-9651 should be helpful, the first link in page 2 describes physical and network setup for ethernet/usb communication. For selecting between the two communication methods, Ethernet will provide lower latencies than that of USB and since the sbRIO-9651 supports Gigabit Ethernet, will also provide a larger max bandwidth than the USB connection. In the first article an example is also referred to which should illustrate communication with the FPGA from your PC:
1. http://www.ni.com/pdf/manuals/376963a.pdf
2. http://www.ni.com/pdf/manuals/376962c.pdf
3. http://www.ni.com/pdf/manuals/376960b.pdf
Ed
