03-11-2013 11:58 AM
When trying to integrate real-time into our vi, nidll_vxworks.tlc does not make a .out file when it is built in Simulink. We get a windows error when trying to build it in Simulink where it says "sh.exe has stiooed working" which gives a model error and the build is aborted.
More background:
We are trying to receive real-time data from two sensors via rs232 serial and the cRIO, which is to be fed into our Simulink model that has been converted into a .dll.
03-12-2013 09:16 AM
WSUcontrols,
Can you provide a more in-depth explanation of what you are trying to do? Is this a problem with Simulink or LabVIEW? Are you using the LabVIEW RT toolkit?
Are you using a serial module on the cRIO9024 or using the onboard serial port?
James K
Applications Engineer
