rs232 communication c++
I would like to write a C++ program to communicate (via rs232) with a temperature oven. I will be using a USB to RS232 adapter. I have never done any serial communication so this is my first trip down this road. I need to setup the serial port on my PC (need the syntax and code) also I need to send commands to the oven and read commands from the oven too.
I'm using the IDE (Code::Blocks) with the GNU GCC Compiler, probably a console application, maybe a Win32 application haven't decided yet. I just need the basics I will try and figure out the rest. Any help in this matter would be great.
What I have read from MANY Google searches is that the serial (rs232) communication is similar to reading and writing to a file. Just need to know how to set everything up.
Thanks any and everyone!!
(4,651 Views)
Before you get ahead of yourself, I would want to be able to communicate to the instrument manually. In other words, I would fire up Hyperterminal and make sure I can command and retrieve information from the oven.
If you are using a NI USB to RS232 device which I hope you are, it should include example programs, maybe not for C++ but it should give you an idea.
(4,643 Views)
Just out of curiosity, what kind of chamber is it ?   I'm having to do the same thing (C++ via RS-232) with a Thermotron chamber.   I can do it with LabVIEW 8.0.1.   (Couldn't get it to work with LabVIEW 2012, so I reverted, and it worked.)
(4,425 Views)
a loopback test can be used to troubleshoot serial communications.
How to Do a Serial Loopback Test
(4,410 Views)
Try this.   It is code that originated from the CVI Examples.   Currently I have the "IDEN?\r" query in it, but it worked and responded with the various commands and queries that I sent it.   This was originally in LabWindows\CVI 2010, but should function as regular C-Code.   (I'm not 100%, though.)
(4,405 Views)
