02-02-2005 04:00 PM
02-03-2005 05:07 AM
02-03-2005 11:28 AM
02-03-2005 11:32 AM
03-14-2008 04:19 AM
I have the same error. I own an old “HP-8753A” NVA and I want to read my measurement data by GPIB with my computer. I use a LabView program from one person who used this at the same NVA type many years ago. At the computer should all install correctly. My NVA use the address 16 and I see this in MAX too.
My problem:
I can read from the NVA but I get information like my below s2p file. My frequency doesn’t change. The frequencies in the file are always my start frequency 300 KHz. At the reading moment I see “Caution: Addressed to talk with nothing to say” at the NVA display.
My NVA use 201 measurement points and my received S2P has this number too.
! 10:50:23 3/13/08
# Hz S MA R 50
3.00E+05 0.00E+00 0.00E+00 1.36E-03 -9.42E+01 3.43E-04 -1.51E+02 9.29E-01 2.42E+01
3.00E+05 0.00E+00 0.00E+00 8.04E-05 -1.24E+02 3.98E-05 -6.37E+01 9.33E-01 -2.71E+01
3.00E+05 0.00E+00 0.00E+00 5.34E-05 -7.57E+01 5.36E-05 -1.39E+02 9.09E-01 -5.04E+01
3.00E+05 0.00E+00 0.00E+00 2.02E-04 -1.02E+02 1.26E-04 4.00E+01 9.24E-01 -7.36E+01
3.00E+05 0.00E+00 0.00E+00 8.45E-05 1.39E+02 3.02E-05 1.02E+01 9.45E-01 -9.88E+01
3.00E+05 0.00E+00 0.00E+00 1.59E-04 1.03E+02 1.14E-04 -1.20E+02 9.55E-01 -1.25E+02
3.00E+05 0.00E+00 0.00E+00 8.88E-05 1.28E+02 7.81E-05 -1.67E+02 9.50E-01 -1.51E+02
3.00E+05 0.00E+00 0.00E+00 4.93E-05 -2.93E+01 2.05E-05 4.21E+01 9.39E-01 -1.76E+02
03-17-2008 12:42 PM
03-18-2008 11:06 AM
A_Ryan
It is funny, if I read with running NI-Spy it works without problems. If I close the Spy software is the problem still the same.
I do not really understand this behaviour?!?! 😕
03-19-2008 09:00 AM
05-18-2009 05:15 PM
hello there,
i've read all your auggestion, very helpful.
i'm using a software test that works along with an 8753ES NA it uses a PCI GPIB card, this NA started today to pop up a message..."CAUTION: ADDRESSED TO TALK WITH NOTHING TO SAY". when i run the NI sw and scan for any instruments makes no sense to me that the first s/n number of my device didn't match with the s/n displayed by the query tasks, i just replaced this NA and use a ENA E5071C, the issue was done while i using a different device but it never solve for me the removed 8753ES issue, do you know if this device needs to be send for repair?
regards
Tech-0
11-02-2011 04:46 AM
The "Addressed to Talk with Nothing to Say" message on the HP8753x screen is not necessarily a bug but a feature:
NWA occupies 2 GPIB addresses; 1 for the device itself, 1 for the display. GPIB name for the device itself is "Hewlett Packard...". GPIB name for the display is null. Once you press "Scan for Devices" in NI Measurement & Automation Explorer, all devices reply with their GPIB address and GPIB name. Since the address of the display is null, the bus indicates that the response of the display is not valid. However it's just a message, it does not affect to the functioning of the NWA or the display. You can get rid of the message by pressing any key in the NWA.
Br.
Juha Ritala
