pcmcia gpib adaptor
Hi
I have a pcmcia-gpib card. Which type adaptor (expresscard, usb) should be used for using for a laptop computer without pcmcia slot? Any suggestions and experience?
Regards
erattag
(3,933 Views)
Pcmcia-gpib card is just for GPIB to PCMCIA, so your laptop need pcmcia slot.  For most of laptop without pcmcia slot, USB-GPIB card is a better choice.
Colin
Colin Zhang
LV7.1/8.2/8.2.1/8.5/8.6/9.0/2010/2011/2013/2015/2016/2020; test system development; FPGA; PCB layout; circuit design...
Please Mark the solution as accepted if your problem is solved and donate kudoes
Home--colinzhang.net: My Blog
iTestGroup: One-step test solution provider!
ONTAP.LTD : PCBA test solution provider!
(3,922 Views)
Thanks. We have three PCMCIA-GPIB cards. Shall we just throw away, or is there any adapter to convert it to usb or exprees card?
Regards
erattag
(3,897 Views)
There are adapters on the market than can connect PCMCIA to USB or ExpressCard, but we really have no idea if they are going to work properly. My experience with PCI to PCMCIA adapters has been that they often do not work correctly, especially for 16-bit PCCARD devices such as the PCMCIA-GPIB. Some adapters work, and others do not. You won't really know until you purchase one and try it.
In general, you are going to see much higher performance and far fewer system compatibility issues if you upgrade to a GPIB-USB-HS or ExpressCard-GPIB. These also have the advantage that they are supported in Windows Vista/7 (including 64-bit), where the PCMCIA-GPIB is not.
-Jason S.
(3,868 Views)
let me know if you are getting rid of the GPIB/PC Card adapters. i need some for my use here in Alaska, but can't afford to buy new ones. doug
(3,695 Views)
