06-05-2008 09:10 PM
Solved! Go to Solution.
06-06-2008 08:20 AM
02-26-2009 06:27 PM
You ever have any luck with a Labview vi for the CN616? I need to program the CN606...don't want to reinvent the wheel.
02-26-2009 07:29 PM
02-26-2009 10:26 PM
It is a 6 channel temp scanner that has the same protocol as the sister CN616 controller.
http://www.omega.com/Manuals/manualpdf/M2818.pdf
I want to read the temp on all channels (thermocouple inputs). I can generate a vi but if you got one it would be greatly appreciated and save me time. I'm just making a simple data logger with visual (3 color bulb type) and audible alarms (horn) based upon input temp readings.
THANKS!
T
02-26-2009 11:59 PM
02-27-2009 01:29 PM
02-27-2009 03:02 PM
03-07-2009 09:01 AM
Hi Jonrviper,
I am also using the Omega CN616 to read and control the temperature of a heating device. Could you please share a copy with me as well?
Thanks in advance.
03-11-2009 12:40 AM
Hello all, I have included my code for the Omega CN616 controllers. I do not guarantee this code in any way or even that it is the best way to write the code. I was a LabVIEW novice when I wrote this code. It runs my controllers well (and exactly how I want them to run). This code is embedded in a much larger program, so speed or CPU power should not be an issue.
I have included sub-vi's to my main code. You have to add 6 text boxes to each sub vi, which either output the current temperature or read in the setpoint. I use a stacked sequence to do this, but I did not include that from the larger code because it seems application specific. You want the set point to default to zero for this program (I've never used below zero temperatures). I also would not recommend trying to ping the controllers more than once a second. Finally I find it works best to wait a second after reading in setpoints before pinging the controllers again.
