nipalk required key not available rhel 8.5
rhel 8.5 in a secure environment with signed  kernel modules.  How do I get the key that is being requested or disable the requirement for this specific kernel module?
I do not find an alternative signed module.  I used the standard down load and I get this:
modprobe: ERROR: could not insert 'nipalk': Required key not available
(1,104 Views)
Accepted by topic author mhz_ghz
found my own answer:
https://docs.tenable.com/nnm/Content/DisableSecureBootforHighPerformanceMode.htm
/usr/bin/mokutil --sb-state
/usr/bin/mokutil --disable-validation
see the article
this disabled the key requirement.
really strange password challenge.  it looped several times asking for individual characters from the password that you supply after the required reboot to disable the encryption requirement in the kernel...
(1,073 Views)
