nipalk fails to compile on Centos 7, NI-software 2019
Highlighted
We are attempting to use ni-software-2019-19.2.0.49152-0+f0.el7
Everything installs without error, but the nipalk driver does not build, even after rebooting. Thus we're unable to use our pci interface.
cat /var/lib/dkms/nipalk/19.0.0f0/build/make.log
DKMS make.log for nipalk-19.0.0f0 for kernel 3.10.0-1127.13.1.el7.x86_64 (x86_64)
Tue Jul 7 18:38:57 EDT 2020
Making nipalk.ko
SHIPPED /var/lib/dkms/nipalk/19.0.0f0/build/nipalk-bin.o
CC [M] /var/lib/dkms/nipalk/19.0.0f0/build/nipalk-interface.o
/bin/sh: line 1: 7665 Killed ./tools/objtool/objtool check "/var/lib/dkms/nipalk/19.0.0f0/build/nipalk-interface.o"
make[2]: *** [/var/lib/dkms/nipalk/19.0.0f0/build/nipalk-interface.o] Error 137
make[1]: *** [_module_/var/lib/dkms/nipalk/19.0.0f0/build] Error 2
make: *** [nipalk.ko] Error 2
Our machine details:
CentOS Linux release 7.8.2003 (Core)
Kernel: 3.10.0-1127.13.1.el7.x86_64 #1 SMP Tue Jun 23 15:46:38 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux
Hardware: 1gig of ram. CPU: Intel(R) Core(TM)2 CPU 6600
(340 Views)
Highlighted
More details on our issue. From /var/log/messages:
Jul 16 15:40:35 rac14rac0 nipal: error: nipalk.ko not found
Jul 16 15:40:35 rac14rac0 nipal: possible cause:
Jul 16 15:40:36 rac14rac0 nipal: nipalk was not versioned for kernel 3.10.0-1127.13.1.el7.x86_64
Jul 16 15:40:36 rac14rac0 systemd: nipal.service: control process exited, code=exited status=1
Jul 16 15:40:36 rac14rac0 systemd: Failed to start LSB: NI Core Driver Services.
Jul 16 15:40:36 rac14rac0 systemd: Unit nipal.service entered failed state.
In the past we could fix issues like this by running the updateNIdriver command, but that isn't provided anymore with the 2019 software.
(229 Views)
Highlighted
Just adding more details. This is from /var/log/messages
Jul 16 16:33:16 rac14rac0 sh: Consult /var/lib/dkms/nipalk/19.0.0f0/build/make.log for more information.
Jul 16 16:33:19 rac14rac0 systemd: Started Builds and install new kernel modules through DKMS.
Jul 16 16:33:21 rac14rac0 systemd: Starting LSB: NI Core Driver Services...
Jul 16 16:33:21 rac14rac0 systemd: Starting LSB: rebind_nismbusd...
Jul 16 16:33:23 rac14rac0 nipal: error: nipalk.ko not found
Jul 16 16:33:23 rac14rac0 nipal: possible cause:
Jul 16 16:33:23 rac14rac0 systemd: nipal.service: control process exited, code=exited status=1
Jul 16 16:33:23 rac14rac0 nipal: nipalk was not versioned for kernel 3.10.0-1127.13.1.el7.x86_64
Jul 16 16:33:23 rac14rac0 systemd: Failed to start LSB: NI Core Driver Services.
Jul 16 16:33:23 rac14rac0 systemd: Unit nipal.service entered failed state.
Jul 16 16:33:23 rac14rac0 systemd: nipal.service failed.
Jul 16 16:33:23 rac14rac0 systemd: Starting LSB: niroco...
Jul 16 16:33:23 rac14rac0 systemd: Starting LSB: nipxicmsd...
Jul 16 16:33:23 rac14rac0 systemd: Starting LSB: NI GPIB enumeration service...
Jul 16 16:33:24 rac14rac0 gpibenumsvc: /etc/rc.d/init.d/gpibenumsvc: line 87: error:: command not found
Jul 16 16:33:25 rac14rac0 kernel: ni488k: Unknown symbol _46020aaee934d79ec654a9e2d2c1b3b9 (err 0)
Jul 16 16:33:25 rac14rac0 kernel: ni488k: Unknown symbol _ZNK21tTimerTimebasePrecise15getCounterValueEPi (err 0)
In the past we could fix issues like this by running updateNIdrivers, but this command is not provided with the 2019 software.
(230 Views)
Highlighted
Accepted by topic author Kevitivity
Update: Adding more ram to this computer fixed the issue. The drivers build and load fine now.
Many Thanks to Marina and support for putting up with us!
(197 Views)
