ni spy 2.5 search is working incorrect
The search function of NI spy 2.5 is use less.
Try to find the line with the text "fast" and it can not find it.
(if you are wondering, line 126 i need to find)
Who programmed this?
This was working fine in the older versions before.
(3,653 Views)
Hi Jewe,
Where do you find the text 'fast' in line 126?
Could you explain what your problem is?
Bas van Dijke
AE, Netherlands
(3,642 Views)
Hi Bas,
in the input buffer there is the text "SCAN:OPTION:FAST SCAN OFF"
regards,
Jeffrey
p.s. in my opinion this is not a "feature reqest", is a bug. the old version was working fine.
(3,636 Views)
Hi Jeffrey,
I see. The Search function doesn't search the buffers. I have created a Feature Request and will also create a bug report.
Bas
Message Edited by Bas van Dijke on 06-13-2007 04:44 AM
(3,633 Views)
Dear Bas,
It's a bug. search for "&" and you will find the strings.
So it does search the buffers.
regards,
Jewe.
(3,628 Views)
