09-13-2007 10:48 AM
09-13-2007 01:35 PM
09-13-2007 02:17 PM
09-13-2007 02:32 PM
I don't have the instrument to experiment with so I would have to speculate. It looks like the command is MEM:DATA? "\d:test.png\". Are you using the regular VISA Read or the VISA Read to File? I have had some problems with large files and the VISA Read to File but you can try both. Does the MEM:CAT command list file size. If it does, then you can use that information to break the operation into several reads.
Your other option is to do what I do for instrument screen printouts. Skip the built in screen dumps and just save an image of the LabVIEW front panel. All of the information on the instrument's screen can be displayed by the VI.
09-13-2007 03:19 PM
09-13-2007 03:46 PM - edited 09-13-2007 03:46 PM
Markers can be displayed as cursors on a LabVIEW graph.
Whether you use a GPIB Read or VISA Read, the operation is the same in LabVIEW. If the header is a known size, do a read of that number of bytes, convert to a number, pass that value to another VISA/GPIB Read, save the results to a file.
Here's some LabVIEW code from an Agilent Scope driver. The principal should be the same.
Message Edited by Dennis Knutson on 09-13-2007 02:51 PM
03-23-2010 04:43 PM
Any body found this solution?
for your information, this equipmenmt is Windows base (win2000), and commands and drives than you put ( \d:test.png\), are saving the data/picture into intrument drive, not into PC. you can access to that files easily using network connection.
in my case I need to transfer that files using GPIB, any body has something?
thank you guys
03-24-2010 06:07 PM
03-26-2010 01:17 PM
here the solution
03-29-2010 11:28 AM
Hi Imontoya,
It sounds like you may have found a solution to your problem. I wanted to verify that this was the case, and if not please clarify your question so we can better help you.
