01-13-2018 08:31 AM
I need to acquire 2 PT1000 and 2 Resistance with myRIO for my application.
In order to achive a good measurements I thinked to implement a 4 wire measurements for the PT1000, and the resistance trought a MAX31865 device.
The MAX31865 has a SPI interface, so my question is how can connect 4(or more) SPI devices to myRIO?
Infact myRIO has only 2 SPI( one for the A MXP and one for the B MXP).
Can you show me an example of code to manage this four devices?
regards
david
01-15-2018 04:14 AM
Hello David15,
myRIO device has an integrated FPGA chip so you can implement multiple SPI communication.
You can use the following API, downloadable from VI Package Manager:
01-21-2018 09:25 AM
Hi Lamber,
I already found and installed the API you mentioned in your post, but I have a broken VI also if I deselect mass Mass Compile VIs After Package Installation checkbox.
And I don't understand how to manage 4 different Cs.
Can the multiple SPI devices be acquire simultaneuslly?Or should I select the CS alternately?
may I manage multiple SPI devices without FPGA programming??
thanks
David
