12-07-2006 12:55 PM
Yes i had installed drivers from too many lecroy oscilloscopes and i needed to find the right initialization VI and keep it in the front of the loop of my program.
thank you
12-09-2006 09:29 PM
12-10-2006 12:00 AM
sorry.
it was my fault.
disregard my old message
12-15-2006 03:36 PM
Hi! Name’s John. Having a bit of a problem making the Lecroy driver work in my setup.
First of – I have Lecroy LC584A. The driver I download from NI.com was lclc5x4a_MS.msi. I then used “Tools -> Instrumentation -> Import CVI Instrument driver” to get lclc5x4a.llb to use with LabView (I have LabView version 7.0, Win98 PC).
I tried opening and running Initialize.vi, but get the following error:
Lclc5x4a Initialize.vi <ERR> Driver Status: (Hex 0xBFFC0011) Identification query failed
Elaboration: Failed to Recognize Model
(??!!!) I thought this driver was supposed to work for all the 5x4a scopes!! My scope’s GPIB address is 9 and the “Instrument Handle” is GPIB0::9::INSTR.
If I try to use any other
12-18-2006 09:36 AM
Hello John,
Alan from LeCroy Tech Support here...
There is a LabVIEW driver for the LC series scopes that should work well with the LC584A: - it's called the "lc3345x4" driver. Give this a try... It should be much easier to use than the IVI driver. Feel free to call me if you have any questions.
Best Regards,
Alan
PS: Here's a link to the download page:
http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=E3B19B3E91B0659CE034080020E748...
12-18-2006 10:03 AM
12-18-2006 10:11 AM
05-22-2011 02:48 PM
Hi Alan,
I stumbled upon this discussion thread while trying to install an IVI driver for the Lecroy LC584AL O-scope. After some difficulties I ended up just using the LT344 driver you mentioned there, and it works just fine. I have a question though - is it possible to aquire an average of waveforms as calculated in the scope? Right now I'm just averaging in LabVIEW, but I wonder if I can speed things up by having the scope do it. Also, do you know where I could find the GPIB commands for the device? I don't see them in the manual.
Clay
05-22-2011 08:30 PM
Hi Clay,
You can setup a math function (e.g trace "TA") to be the "Average" function. I believe that this was standard on the LT series, but I'm not 100% sure. You can readout the math functions with the LabVIEW driver, and you can also poll to determine when the averaging is complete. (There are bits in the INR change register for this purpose.)
Since this thread was created, I have moved out of the AE group, but the other AE's can certainly give you further assistance - please give a call to 800-553-2769 for more support. The commands are in the Remote Control Manual: http://www.lecroy.com/files/manuals/WR2_RCM_RevB.pdf
Best Regards,
Alan
05-24-2011 01:06 AM
Hey Alan,
Thanks much for the response. It was helpful and most appreciated.
Clay
