labview 7 to labview 6.1 conversion
Can someone convert the attached lib file for me?  it is in LabView 7.0 and I need it in LabView 6.1.
Thanks in advance.
(3,940 Views)
Here you go.
(3,905 Views)
I have just the same request. I would be very thankful if somebody can convert the following library from LabView 7.0 format to LabView 6.1 format.
Many thanks in advance!
(3,858 Views)
Here it is. I hope you have PerformaxCom.dll. You didn't include that with your post and it's required to run the VIs.
p.s. Next time you need something like this, it would be better to start a new thread.
Message Edited by Dennis Knutson on 01-15-2007 07:31 AM
(3,838 Views)
Thank you for the help!
I have a DLL file and the conveted file appears to work fine.
Michael
(3,820 Views)
