keithley 2000 on which addres it write data from keithley to LabVIEW
Hi Guys...........
i want to connect keithley instru. to LabVIEW. One problem is that for write/read which address is pass by me so i can able to W/R the data of keithley.
if any exmlple then send link also...........
(3,627 Views)
The address of an instrument is whatever you set it to. Some instruments have a dip switch that you set and others can be set from the front panel. The details should be available in the instrument's manual. If you don't have the manual, contact Keithley.
(3,623 Views)
You can see the address when powering up the keithley 2000.
It is shown only a short time so look carefully, and you may have selected the serial interface so check config.
greetings from the Netherlands
(3,596 Views)
