i can not send data to serial port but i can receive data from serial port
Dear Engineer
I have a problem about serial port
i can not send data to serial port but i can receive data from serial port .
please help ma about this problem
thanks & best regards
(3,238 Views)
Hi ehsanbehr...,
what have you done? Did you try it with the shipped examples (Basic Serial Read and Write.vi)? Can you communicate over hyperterminal with your device?
Mike
(3,237 Views)
Mike is right.Once ur able to establish a connection and communicate using the hyperterminal then it means u r doing an error in lv.Try hyperterminal first to make sure it is  abt lv.
(3,225 Views)
Are you are able to query the device for its device identifier? If you can *IDN? the device, then you can communicate. Also, try and use VISA test panels to determine what is taking place in the communication stream. One more thing to check is to make sure your baud rates are correct. Also, performing a loopback test can determine if everything is functioning properly.
(3,182 Views)
