07-17-2016 01:42 PM
hi
i write a program in ARM lpc1768 for A/D converter and send the result to pc by serial port in labview that i attach the design.
i can recieve data in binary and numeric.
now i wanna plot this data into the garph like time/amplitude (real time) but i cant import the data as input for the wave form chart
hope to someone can help me in this case!
07-17-2016 08:41 PM
What is the protocol you created with your ARM program? Put another way: How is the message your ARM microcontroller you are sending the the PC formatted?
07-18-2016 05:24 AM
dear crossrulz
i designed the plotting part
but now i have an another problem that cant troubleshoot it
when i sending data from processor, i recieve it correctly but the chart only show the first recieved data and others just show in read string box
i attach my design so you can see it and tell my mistake
thanks alot
07-19-2016 11:58 AM
What are you expecting to acquire? what is what you are receiving? it is posible that you are losing some information on the conversion of data.
07-19-2016 12:06 PM
Your problem is that you are just concatinating the read string and doing the conversion on the entire string, which will only return the first value. Again, what is the protocol you are using for the serial communications? You can simplify your LabVIEW code a lot if you have a termination character.
07-20-2016 03:11 PM
i use usb to send data
is it possible that usb cant provide the sufficient rate to send/recieve data?
07-21-2016 03:15 AM
09-28-2016 06:30 AM
Hi Ben,
Im sorry that Im not here to give solution, but to ask you another question. How do I port my ARM embed LPC1768 in Labview? I cant find any working solution for this porting guide. There is no connection in NI-MAX for my embed so I cant get its serial port name in the front panel.
I refer to this link https://developer.mbed.org/cookbook/Interfacing-with-LabVIEW but I get stucked at the first step.
Thank you
09-29-2016 09:28 AM
hi there
its so simple,after you connect your arm to your pc with usb,then just use the block "VISA Serial"
for more help,i attach my design,hope to find it usefull 🙂
09-29-2016 11:00 AM - edited 09-29-2016 11:03 AM
@benyamin wrote:i use usb to send data
As crossrulz mentioned earlier you have an issue where you are A) Missusing a Chart B)reconverting the first 4 characters received only C)failing to convert all data recieved and likely converting those characers to the wrong representation. And, your BD is something of a mess (OK "Unmake Space" help clean up the BD a lot! and you don't have that available in 2014- its a 2015 and later feature)
To get you going in a "righter" direction I made some mods and attached a code capture in 2014. THERE ARE almost certainly still problems! When you tell us what the format on the received data is (not HOW you transfer it but, what the strings represent such as: ASCII encoded numeric characters or, 8 bit ADC Counts to string or, other.) we can help iron out those conversions as needed
