10-21-2013 10:53 AM
I recently installed the PCI-8431/2 and I'm trying to run a loopback test, but I'm getting this error:
VISA: (Hex 0xBFFF0011) Insufficient location information or the device or resource is not present in the system.
I have already used the installation CD, but I don't know if I did anything wrong or missing to do something.
Thank you
10-21-2013 10:58 AM
Do the serial ports show up as COM ports in the device manager? Can you see the COM ports in MAX?
10-21-2013 11:05 AM
I manually added the COM1 and COM2, but they appear as not present.
10-21-2013 12:23 PM
I think I don't have installed the correct software, could you help me with the correct one? I'm trying to use the serial port from a PCI 8431/2
10-21-2013 12:26 PM
I think that card just needs NI Serial for the drivers. You should also make sure you have VISA installed.
10-21-2013 12:28 PM
I have downloaded VISA two times, but I don't know if I'm installing the correct version. Do you have the link where I can download it?
10-21-2013 04:10 PM
