how to debug a PCI resource conflict
I have recently replaced the ADLINK PCI-7432 with the NI PCI-6515, these are 2 very similar Digital IO cards.  I was forced to ditch the Adlink card because it's not supported for the more recent versions of LabVIEW.
The NI PCI-6515 works as expected, however, when I make the swap, the card in the next PCI slot, the MOXA 8-port serial card CP-118U disappears from Device Manager.
If I move the MOXA card to an alternative slot, it reappears in Device Manager, but this is not a solution because the cables don't reach to the other end of the large PCI back plane.
I believe this is a PCI resource conflict, how to I debug/fix to make the MOXA card continue working in it's original slot position?
(2,681 Views)
for debug, WIN+R -> msinfo32
for solving this issue, devcon utility
https://docs.microsoft.com/en-us/windows-hardware/drivers/devtest/devcon
Good Luck!
(2,644 Views)
